It is currently Sat 12. Apr 2025 2:06:46
PostPosted: Thu 28. Sep 2017 20:07:30
Hello There,
Everything is connected as per the manual, and I've re-flashed the unit to stop the "always in binding mode" issue. The FBL satellites and the SPM4649T are all bound correctly it seems!
Issue 1 --- Can't Access Integration
When I scroll to the right after turning on the transmitter, there is No blank screen :|
Issue 2 --- No Telemetry Data
I've selected the Kontronik Jive Pro option in the software.
I can scroll through the various DX9 telemetry screens, but no data is displayed :|
Edit: My DX9 has been successfully updated to have the latest Firmware and AIRWARE.
Please can someone provide any suggestions they can think of?
Cheers, Gary.
PostPosted: Thu 28. Sep 2017 20:12:36
in the Telemetry settings of your transmitter you can go to the Text Gen and edit options to show at the Roller.
This should give you the Blank screen.
After this the integration should work. If not, then it is answer for the second issue.
Do you see the Telemetry signal in the left corner?
PostPosted: Thu 28. Sep 2017 20:24:57
In the top left corner there is a series of vertical lines. Is this the Telemetry signal you mentioned?
I'm not sure what "Text Gen and edit options to show at the Roller" means though. I've enabled various Telemetry features in the Tx but all the data shows dashed i.e. ---- so no data values.
The Tx Telemetry main screen has two initial menu options, "Settings" and "File Settings". Within the "Settings" one of the menu options is "Display" currently set to: Roller.
Anyway I'll have a play to see if anything changes :)
PostPosted: Thu 28. Sep 2017 20:29:10
Yes, this is the signal.
Did you performed transmitter preparation step?:
http://manual.spirit-system.com/index.p ... reparation
PostPosted: Thu 28. Sep 2017 20:37:32
I have now :D
So the integration works now :)
I'm just checking the Telemetry. Back soon.
PostPosted: Thu 28. Sep 2017 20:42:42
Yes the Telemetry is showing values now.
Sorry, it was my fault for missing out the transmitter preparation step :oops:
Thanks again :roll:
PostPosted: Thu 28. Sep 2017 20:46:36
Good job :)
Users browsing this forum: curmudgeon and 6 guests
