Spirit System
[SOLVED] Jeti receiver - EX Bus Settings
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2230
Author:  Malc1 [ Tue 19. Sep 2017 7:39:03 ]
Post subject:  [SOLVED] Jeti receiver - EX Bus Settings
New build now finished and set up and just running through everything and noticed a few corrupted frame error messages and a low voltage error in the logs.
Are the correct recommended configuration settings to work with the Jeti EX Bus and Spirit available?
Just so I can be 100% sure that I have not missed anything early on.
Author:  ZeXx86 [ Tue 19. Sep 2017 8:47:01 ]
Post subject:  Re: Jeti receiver - EX Bus Settings
If you will turn off the transmitter before power supply for the unit then it is registered as Low Voltage event + possible lost signal event.
In this case all is OK. But if it will be there even if transmitter is running it is not good.
Corrupted frames could happen from time to time, especially if you are changing the settings.
During flight there should be maximally 1-3 corrupted frames.
Author:  Malc1 [ Tue 19. Sep 2017 9:28:12 ]
Ok thanks I will test further later on without the unit connected to the software and check the logs.
Author:  Malc1 [ Tue 19. Sep 2017 18:13:25 ]
So If no log is available from the previously flight that is no errors at all during the powered up period?
Author:  ZeXx86 [ Tue 19. Sep 2017 19:55:08 ]
Yes, if there is no critical error, then there will be no saved log.
http://www.phpbb.com/
