It is currently Sun 24. Nov 2024 9:57:24
[ 4 posts ] |
Heli1458
Posted: Mon 25. Sep 2017 20:19:50 |
Hello. Can the OpenTX integration of FRSKY be used with additional sensors? I have a Spirit Pro, Hobbywing Platinum Pro V3, FAS40s current sensor and an X6R S.Port receiver. Can the integration cable also be connected to the FAS40S? Is it possible to display the RPM output of the Hobbywing as a telemetry value if you do not use the Govenor of the Spirit?
Excuse me for my bad English, I've used a translator.
greeting Klaus
Posted: Mon 25. Sep 2017 20:24:40 |
answer to all your questions is: Yes.
You can use more sensors at the same time. Unfortunately we have no experience with FAS40s sensor. Since HobbyWing V3 does not support telemetry as V4, you will need to use the RPM lead from your ESC. But the result will be same.
Heli1458
Posted: Mon 25. Sep 2017 20:42:43 |
Thanks for the quick reply, I will try this time. I thought the Spirit pro would turn the hobbywing's speed as a telemetry value give. Thanks and regards Klaus
Posted: Mon 25. Sep 2017 20:46:30 |
Yes, it will be as telemetry value.
You are welcome!
[ 4 posts ] |
Users browsing this forum: No registered users and 36 guests |
