It is currently Sun 24. Nov 2024 7:52:46
Page 1 of 1
[ 3 posts ] |
Author |
Message |
PeteMarr
Posted: Tue 05. Sep 2017 19:17:19 |
Has anyone tried to link the µSpirit and SPM4649T? If so, can you share how you wired it.
Top |
Coco66
Posted: Wed 06. Sep 2017 5:04:42 |
Joined: Sun 26. Jul 2015 8:17:50 Posts: 433 Location: Madrid, Spain / Torino, Italy
Well, it's depending if you want to use the integration or not...
For a normal connection, I used Red and Black to RUD (for power) and Blue to SAT (for signal). From the longer Receiver cable, the one with the male plug.
For integration you need the same for power, and the signal to the Ail pin, and use the shorter Receiver cable, the one with the female plug (called Bind/Prog in the Receiver manual).
For the second you will need FW 2.4.3 and some additional configuration as per the guide.
_________________ Oxy 2 ♦ X-Vert ♦ Warp 360 ♦ Blade 450X ♦ Blade 450X Nightflyer ♦ Goblin 500 (RIP) ♦ 2 X mCPX v2 ♦ night fly mQX ♦ LadyMQX ♦ nano QX ♦ nano QX FPV ♦ Inductrix ♦ DX8 G1
Top |
PeteMarr
Posted: Wed 06. Sep 2017 19:18:05 |
Thanks, That worked perfectly.
Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 28 guests |
