It is currently Sun 24. Nov 2024 9:51:29
[ 3 posts ] |
Malc1
Posted: Wed 20. Sep 2017 18:25:57 |
I am using the internal governor on a Scorpion Tribunus 200A esc and have RPM data being displayed on my Jeti TX. Will this be the correct RPM being displayed? I have noticed that in the Scorpion software when running the motor the RPM is much much higher and certainly can not be the RPM of the rotor head.
Or do I need to be using the Spirit governor for this work correctly, and be able to use it to set up the helicopter? I have previously set up the correct main gear ratio in the Spirit software.
Posted: Wed 20. Sep 2017 18:34:38 |
You have to set Sensing Divider and Gear Ratio. Then it should match the head speed. This can be done in the General - Governor/Throttle window (after enabling Governor temporarily).
Malc1
Posted: Wed 20. Sep 2017 19:47:07 |
Great! Many thanks again.
[ 3 posts ] |
Users browsing this forum: Bing [Bot] and 43 guests |
