It is currently Mon 25. Nov 2024 4:58:17
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
 Post subject: WIFI Module question
PostPosted: Tue 01. Aug 2017 13:49:43
i have an issue with my wifi modules on all spirit's.
If i connect the battery and the system starts up i don't have a working wifi (solid blue LED)
I have to disconnect and connect the wifi module (the rest of the system still has power) to get the wifi module to work.
any hints ?
thank u
 Post subject: Re: WIFI Module question
PostPosted: Tue 01. Aug 2017 13:51:44
where is your wifi module power cable connected?
PostPosted: Tue 01. Aug 2017 13:52:46
direct connection to the bec
PostPosted: Tue 01. Aug 2017 13:56:53
Can you try to connect it directly from the unit or receiver? So that it is powered from the same bus as unit.
PostPosted: Tue 01. Aug 2017 14:04:16
i did, same result. ( receiver and spirit)
PostPosted: Wed 02. Aug 2017 10:18:36
Hi Tomas,
some more infos for you:
frist spirit is connectet via hobbywing 100 A V3 internal BEC (500 scale)
second is connected via roxxy 960 BEC (500 Trainer)
third is connectet via MTTEC KETO HV BEC 12s 10A V2 (550 Trainer)
PostPosted: Wed 02. Aug 2017 10:48:46
Thank you for the details.
Does it happen from the beginning?
We can send you new Wifi-Link to try.
It should not happen on any helicopter.
PostPosted: Wed 02. Aug 2017 11:30:32
Well,
i connect my Wifi modules to the spirit of a friend and they worked as they should.
so we disconnected the wifi module link from sys of the spirit and connected the battery. the module worked as designed.
if we plug in the module link back on sys to the spirit,then power up, the wifi module dosen't come up.
any clues ?
PostPosted: Wed 02. Aug 2017 11:40:21
Do you have updated Spirit unit?
PostPosted: Wed 02. Aug 2017 13:40:03
Sorry forgot to mention that:
all spirits 2.4.2
all wifi's 2.4.1
the only difference we can spot is: my friend has SBUS and i have all standard PWM receivers
Users browsing this forum: Bing [Bot] and 69 guests
