It is currently Mon 25. Nov 2024 4:44:41
 Post subject: HobbyWing ESC Telemetry
PostPosted: Sun 13. Aug 2017 13:03:58
The HobbyWing Platinum 60A V4 esc is the ideal size for my application (Compass Warp with Spirit FBL controller). The 80A is just too big to fit.
The online Spirit manual states the HW 60A esc is the only size that does not provide Battery Current and Consumed Capacity. Is this still the case or does a firmware update change this?
PostPosted: Sun 13. Aug 2017 14:19:00
60A has no current sensor inside, so it is technically impossible to implement it.
Another possibility is to get for example CC Phoenix Edge (Lite) ESC which is available in similar or smaller size.
PostPosted: Sun 13. Aug 2017 23:07:08
Hi...
but with the edge, we cannot measure more than 2500 rpm if I understand correctly ...
PostPosted: Mon 14. Aug 2017 7:43:54
It can measure 20000 RPM, but if your motor is spinning faster, then it is problem.
On a bigger helicopters it is OK.
But with these ESCs you have also RPM lead wired out, so you can use it for measurement as well.
On the other hand internal governor is probably not working that well as of HobbyWing.
PostPosted: Tue 15. Aug 2017 7:31:49
Thanks for the reply. But it is sad news for me. Why would HW not include current sensing ability?
PostPosted: Tue 15. Aug 2017 7:49:27
Because it will not fit sensor on the board and also it would be more expensive.
So probably these are reasons for such decision.
Users browsing this forum: Google [Bot] and 77 guests
