It is currently Sun 24. Nov 2024 20:22:27
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Mon 31. Jul 2017 9:14:41
Just setup a Spirit pro (2.42) on a 700 with HV servos using 2x DSMX sats and a DX9. Im running a external bec with 2 outputs and would like to run an ultraguard as well. Can i run the bec into RUDD and AUX2 and still assign AUX2 for Separate Channel Stabi? Also can i use channel 0 for the ultraguard? Will this leave me a free channel for bank switching or will i need to run a SRXL rx to free up channels to do this?
Thanks.
PostPosted: Mon 31. Jul 2017 10:54:38
if you are using satellites or SRXL receiver, all channels are transmitted to the unit. So you can use any other available port and still utilize any channel you want (including channel for Bank switching).
So you can use RUD, AUX2, CH0 ports for anything you want (BEC, ultraguard).
AUX1 will be used for the ESC.
For bank switching you only have to assign Channel 7 in the General/Channels window.
PostPosted: Mon 31. Jul 2017 11:17:50
Thank you for the fast reply. I though that mite be the case but I wanted to be sure.
Great unit guys so far im impressed, cant wait to get it in the air.
Thanks heaps :D
PostPosted: Sun 06. Aug 2017 12:57:38
You are welcome!
Users browsing this forum: mainstreet and 45 guests
