It is currently Sun 24. Nov 2024 6:28:33
[ 6 posts ] |
tiriips
Posted: Wed 26. Jul 2017 3:15:11 |
My main gear is 150 teeth, motor has 9 so my ratio is 16.66
But i dont seem to be able to select above 12 ???
Is there a simple workaround or am I missing something
Posted: Wed 26. Jul 2017 11:30:11 |
What helicopter do you have? Do you know motor pole count?
Yes, there is a workaround so it will work well.
Increase Sensing Divider so that value of Gear Ratio * Sensing Divider is same or near. This mean, if you have 10 poles (5 for sensing divider) than result will be: 16.66 * 5 = 83,3. 7 for sensing divider and 11.9 as gear ratio will give you the same result.
If you can give motor pole I can tell you exact values.
Coco66
Posted: Wed 26. Jul 2017 12:16:13 |
Tomáš, why do we have those limits? Are they really needed? all these "workarounds" are confusing (the other one is about RPMs)...
tiriips
Posted: Wed 26. Jul 2017 12:24:32 |
Hk 450 pro - motor is turnigy x500-4000 6 poles I think
Posted: Wed 26. Jul 2017 12:59:44 |
Coco66: The limits are very same as what you can find for example in the VBar. Normally such gear ratios are abnormal. At the time it was designed there were basically no cases like this. New update will have wider range.
tiriips: Set Sensing divider to 6 and Gear Ratio to 8.30. Then it will be fine.
tiriips
Posted: Wed 26. Jul 2017 22:47:36 |
Thanks Z, I feel like I should have known.
[ 6 posts ] |
Users browsing this forum: Bing [Bot] and 19 guests |
