Cyclic Gain effect during Stabil/Coax ? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2023 |
Page 1 of 1 |
Author: | zr1100 [ Mon 05. Jun 2017 16:41:12 ] |
Post subject: | Cyclic Gain effect during Stabil/Coax ? |
Does "Cyclic Gain" in "Sensor" tab affect banks that are enabled for normal stabilization and coaxial? If so, what is recommended for a starting point--ie. same as on regular flight bank with no stabi enabled? PS--any tips on cyclic gain range in normal flying mode (disabled stabi) would be welcome also--currently set at 65--on 500 size heli. Thanks |
Author: | ZeXx86 [ Mon 05. Jun 2017 16:48:48 ] |
Post subject: | Re: Cyclic Gain effect during Stabil/Coax ? |
Hello, you can use the same value as for normal flying. It is affecting both stabilisation and normal flying mode in the same way - higher cyclic gain - higher precision/stability. But Spirit can fly well even with the lowest cyclic gain - the feeling is just more natural. I do not recommend to go too high (over 70%) on this model. Usually value around 65% is optimal. But you can start with default (55%) with no worry. |
Author: | zr1100 [ Tue 06. Jun 2017 19:20:06 ] |
Thanks very much! |
