It is currently Sun 24. Nov 2024 4:02:42
PostPosted: Mon 05. Jun 2017 18:30:28
Just bought a Trex 800 Pro DFC and want to use a spare Spirit (not Pro) I have.
Plan is to run two Spektrum satellites (one with Spirit adapter to RUD pins) and no receiver. Power will come from a 2S lipo receiver pack.
PROBLEM: With everything plugged in to the Spirit, I only have one set of pins, AUX, available for power. SYS and ELE/PIT/AIL can't be used for power, and the other 4 each have a servo plugged into them.
The Trex has brushless servos which are not supposed to be power hogs, and it passed Spirit's BEC test, but it's a really big heli and I would be more comfortable with two power leads.
Is there a way?
PostPosted: Mon 05. Jun 2017 20:07:36
Hi, you an use Y Cable on any servo Port and connect 2nd Power to it together with the Servo.
PostPosted: Tue 06. Jun 2017 1:38:58
Perfect! Thanks Adrian. Just ordered one.
Don (in Florida)
Users browsing this forum: No registered users and 54 guests
