SRXL channels https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1975 |
Page 1 of 1 |
Author: | George Baker [ Sat 13. May 2017 4:54:17 ] |
Post subject: | SRXL channels |
Hi, I'm using a Spektrum SPMAR9020 nine channel receiver to send 5 channels (PWM) to a standard Spirit gyro. If I connect the SRXL pin on the 9020 receiver to the RUD pin on the Spirit (and select SRXL receiver type in software) how many of the 9 channels of the receiver will be available? Will it still only be 5 channels? If it makes a difference my transmitter is a 12 channel Walkera DEVO 12s w/deviation firmware. NOT a Spektrum TX. |
Author: | ZeXx86 [ Sat 13. May 2017 8:31:36 ] |
Post subject: | Re: SRXL channels |
Hi, with SRXL connection it should be all the channels that transmitter offer. But in case of Walkera I am not confident how it will work. You can get also AR7700 which is smaller but also offer SRXL connection. |
Author: | George Baker [ Sat 13. May 2017 16:07:42 ] |
Thank you for the answer. I will check with the TX firmware developer or I may just try it and see what happens. Would be nice to have more than 5 channels although I haven't really needed to adjust my rudder gain which I have to do in the software instead of the TX. |
Author: | b-bird [ Sun 14. May 2017 21:51:10 ] |
i´m using an AR8010T with SRXL on Spirit, all Transmitter Channels can be used. |
