It is currently Mon 25. Nov 2024 8:00:05
Post new topic Reply to topic  [ 9 posts ]
PostPosted: Wed 10. May 2017 10:48:05
Hello!
I use the jeti intigration. Now I would like to connect the ESC telemetry. JivePro and REX6 with the Telem Kontronik cable.
How do I connect them?
Is there an RPM "signal" soon?
greeting
PostPosted: Wed 10. May 2017 10:54:02
everything is described in our guides :)
Links for them are also directly in our software so if you will just look at the ESC Telemetry, you will find everything needed.
http://manual.spirit-system.com/index.p ... lemetry/de
PostPosted: Wed 10. May 2017 14:04:41
OK thanks!
But the ELE / PIT / AIL slot is occupied with the Jeti intrigation cable ...
Is this no longer required?
PostPosted: Wed 10. May 2017 14:10:39
It is required, but Jeti integration is using only AIL pin. Kontronik ESC telemetry is using ELE pin. So all can work together.
PostPosted: Wed 10. May 2017 14:19:18
Ok, that was my question.
Now I know, thank you!
PostPosted: Fri 12. May 2017 13:16:07
Hallo
I have a new Spirit V2.4.0 via Jeti RSAT2 Ext. and a Jeti Speed Controller SPIN Pro 44 Telemetry on AUX.
Everything works, except Telemetry data from the SPIN.
I just have S Vibs% and S Volt. I was waiting over 10 min. for synchronizing telemetry Values, nothing.
Is it integrated or not?
PostPosted: Fri 12. May 2017 13:30:40
The Spirit unit does not support Jeti ESCs, since they can be integrated directly with receiver by EX Bus.
So you only have to set correctly ports in the receiver.
PostPosted: Fri 12. May 2017 13:45:13
Thanks for the fast response.
In this case, I cannot use RSAT 2. Port Ext. is in use for Spirit. PPM out cannot be configured for channel 1 throttle.
I have to order, at minimum, the new Jeti Duplex REX 3, there I can configure it.
Thanks.
PostPosted: Fri 12. May 2017 15:20:20
You are right, I have overlooked that you are using RSat.
In this case you will really need at least REX3 with 2 EX ports.
Users browsing this forum: No registered users and 15 guests
