It is currently Sat 23. Nov 2024 23:39:22
 Post subject: Oxy 3 Tail Wag (HELP!)
PostPosted: Mon 24. Apr 2017 1:51:27
This is my first time using the Spirit and set up was easy having read up and followed this forum here and on HeliFreak. I bought the Oxy 3 255 used with only a few flights on it. Never been crashed, etc. I tore the entire heli down and rebuilt it. I finally had a chance to maiden it a few days ago. I was expecting it to be rock solid but found that the tail doesn't hold well and has a slow wag. I know the Oxy's need a few break in flights so I didn't worry about it too much. I've been through about 5 batteries of hovering, pitch pumps, around the yard, etc.
The tail still has a slow small wag maybe an 1 - 1.5 inches not constantly but very frequent. I've upped the tail gain from 40-85 so far with no seen difference. I also changed the piro consistency to 170. I took the entire tail apart and couldn't find anything mechanically wrong. The tail moves freely throughout its entire travel.
I remembered the analyzer in the software and decided to give it a try. On the elevator and yaw axis all the vibes are below 15 magnitude across the entire spectrum. On the aileron axis it is showing between 70-90 magnitude coming from the head around the 3200-3500 rpm. That is with the main blades off the heli and the tail blades on. I've spent several hours taking the main gear, shaft, motor etc apart and checking for any problems. With the motor backed off of the main gear the vibes return to below 15 magnitude on the scale. I assumed the vibrations had to be coming from the main gear area then. The one way bearing is smooth and works correctly. The main gear looks to run true with no out of round. I put it all back together and took it for a very quick hover a few minutes ago. The tail still does not hold perfectly, after 10 seconds or so the tail will drift a bit. It did seem like the tail wag was a bit improved. It didn't seem to be as frequent. Pitch pump still has the tail blowing out 25-30 degrees.
I'm using the Hobbywing 50 v3 governor if that makes any difference. It was rock solid on my Forza 450. I have tried headspeeds between 3100-4000 rpms (approximately). Let me know what you think I should try next. Thanks!
Edit: I'm running KST215MG servos all around. Here are my settings:
Oxy3 255 4S 4-23-17.4ds [255 Bytes]
Downloaded 29 times
PostPosted: Mon 24. Apr 2017 18:22:19
Anyone?
PostPosted: Mon 24. Apr 2017 19:07:06
if it is slow tail wag then it is in 98% cases unfortunately mechanical issue - something is not as smooth as it should be.
Usually this problem is in the push rods/ball linkages. They should move with completely no friction.
You can decrease Pirouette Consistency to 160. With higher value, the issue will be probably more visible.
You can also decrease Rudder Delay to 0. The servo itself is not designed for Rudder usage, so performance might be not perfectly ideal, but still it should be possible to tune it well as it is fast enough.
In smaller helicopter governor might need to be tuned (decrease gain) - this could be theoretically the issue too. Each helicopter size need different PI gain to work optimally.
PostPosted: Tue 25. Apr 2017 2:55:25
Thanks ZeXx86. I checked the entire tail tonight from grips all the way back to the servo. All grips, sliders, bell crank, push rod and ball linkages are silky smooth. I changed both the PC and Rudder Delay as advised. I will try to get a test hover in tomorrow if the rain decides to leave.
There are no governor settings available on this esc. I may try to use just a simple linear curve and see if that helps if I still get the wag. Did the rest of my settings look good? Should I be worried about the magnitude of vibes or the number to the right under vibrations? The magnitude is high on aileron but the vibration number is low and says good. A little confused on that part. Thanks for the help ahead of time.
PostPosted: Tue 25. Apr 2017 7:31:22
Yes, rest is good.
HobbyWing governor has PI settings, but it is available only in the ProgBox or PC software.
Turning governor off is good idea, this will tell you immediately if this is the reason.
PostPosted: Tue 25. Apr 2017 8:25:56
Only V4 has programmable PI for governor. He has V3 and PI can't be changed...
Users browsing this forum: Amatrix and 30 guests
