It is currently Sat 23. Nov 2024 23:39:01
PostPosted: Wed 19. Apr 2017 13:17:07
Hi serviceteam,
setting my spirit system (standard) after update - setting channels seams to be fine. Pitch movement is shown at general channel setting as well. But if i try to use pitch under normal circumstances - it doesn't work.
Second - setting direction of each channel has be done and works properly but - if Helicopter will be moved to one site (aileron) Spirit systems moves to same direction - but has to move against this direction
Any idea?
thanks in advance and br
siggi
PostPosted: Wed 19. Apr 2017 19:55:37
Direction: This can have different reasons, usual if followed installation wizard, this should work.
Causes, Spirit pointing to wrong flight direction or servo plugged in on wrong ports in Spirit.
PostPosted: Wed 19. Apr 2017 22:28:47
Hi Adrian,
I fixed one issue - dircection of contra movement while moving heli has been fixed - I set reverse movement in spirit and normal at TX.
last issue - no pitch movement. Pitch traveling is shown at diagnostic tabs from spirit - therfor signal must be known at spirit
Aileron, elevator, rudder, rescue mode works fine.
Thanks supporting me br siggi
PostPosted: Thu 20. Apr 2017 7:03:18
If you're not getting any pitch (collective) you have rescue enabled & active.
PostPosted: Fri 21. Apr 2017 11:55:42
Hi jgiannakas,
you are right - I have a mixer at TX and this doesn't work properly (after updating TX Software).
thanks and br
Siggi
Users browsing this forum: Amatrix and 29 guests
