micro spirit https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1934 |
Page 1 of 2 |
Author: | lostmyheli [ Wed 19. Apr 2017 11:35:50 ] |
Post subject: | micro spirit |
Package content •μSpirit unit •USB interface (1 meter long) •1x 65mm JST-RX receiver cable •1x 65mm JST-Servo cable •3M doublesided adhesive tape Does the JST Servo cable accommodate all 4 servos ? |
Author: | ZeXx86 [ Thu 20. Apr 2017 7:15:33 ] |
Post subject: | Re: micro spirit |
JST-Servo cable is used for USB interface (when connected), but can be also used for one of the servos if you have with servo connector. If all 3 servos are with servo connector, you might need at least 2 servo adaptors or to change the connectors. We can also do the replacement for you. Or you can buy directly servos with JST-ZH(R) so no adaptor will be needed. For example Eflite offer such servos. |
Author: | MyRCode [ Tue 25. Apr 2017 6:38:34 ] |
Any update on the ETA? Sent from my Pixel using Tapatalk |
Author: | ZeXx86 [ Tue 25. Apr 2017 7:23:50 ] |
Yes, 1 - 2 weeks. All the parts are in process of manufacturing, then we will ship immediately as we will got them. |
Author: | lostmyheli [ Tue 25. Apr 2017 13:53:16 ] |
Looks good got one on preorder. Now any updates on GPS ? |
Author: | ZeXx86 [ Wed 03. May 2017 8:45:24 ] | |||
Post subject: | Re: micro spirit | |||
It is nearly here!
Author: | lostmyheli [ Tue 09. May 2017 0:02:24 ] |
Any update on ship date ? Thanks |
Author: | ZeXx86 [ Tue 09. May 2017 7:00:01 ] |
Today we will receive the most important part of the uSpirit. But all should be ready in the next week. Because of week delay, we will add free gifts for all preorders |
Author: | pepr [ Fri 12. May 2017 18:10:43 ] |
Some time ago you mentioned you where testing the possibility of using the mSpirit on a T-rex 150. You even explained witch pin of the ESC goes where on the unit. Was the attempt successful. I'm very interested in trying that and any info would be greatly appreciated. . Envoyé de mon SM-G920W8 en utilisant Tapatalk |
