Chronos tilts at low rpm via nick and roll https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1922 |
Page 1 of 2 |
Author: | sascha1603 [ Thu 13. Apr 2017 18:30:26 ] |
Post subject: | Chronos tilts at low rpm via nick and roll |
Hello In my Compass Chronos I have the following problem In the bank 0 at only 1250U / min he partly rolls over roll and Nick when he is on his back! Usually when I take it deeper and then intercept, or quite calmly on the back hovering and let him stand thus without input, he suddenly kicks away slowly With the other banks it is not Have already put the gain on 75 and 70, without improvement When the Spirit was in the 7HV was not the case What could I adjust? Greeting Sascha |
Author: | ZeXx86 [ Fri 14. Apr 2017 9:54:28 ] |
Post subject: | Re: Chronos tilts at low rpm via nick and roll |
Hello, if the problem is not in Bank 0, then there is some settings that is causing it. Can you please send me settings from all the banks so I can see difference? You can also use Bank comparison feature and see what is wrong. Maybe it is some settings from your transmitter. If your Banks are assigned as a different Flight modes, then it is possible you have some subtrims/trims configured in this modes. This can be also visible in Diagnostic tab. |
Author: | sascha1603 [ Fri 14. Apr 2017 10:27:14 ] | ||||
Post subject: | Re: Chronos tilts at low rpm via nick and roll | ||||
Hello It's only in bank the problem In the transmitter, all banks are the same, trim is deactivated and only the bank switch, gyro and speed is changed, no expo or dual rate In appendix 00 bank 0 11 Bank 1 22 Bank 2 Greeting Sascha
Author: | ZeXx86 [ Sat 15. Apr 2017 14:27:59 ] |
Hello, I can see that there are some slight differences between banks. But are different banks also with same RPM? If RPM is not same, then this is the big difference. Unfortunately from your description, I am not sure if I understand the problem correctly. Can you describe it little bit more? In any way, what you can try is: 1) go to Servos tab 2) enable Subtrim (tuning) 3) check if the servo arms are perpendicular at this moment 4) check if the swashplate is level 5) check if there is 0° between main blades Are these things OK? |
Author: | sascha1603 [ Sat 15. Apr 2017 16:54:27 ] |
Hello Yes, different speeds, bank 0 1280U / min, bank 1 1550U / min and bank 2 1950U / min The problem is, if the heli is hovering on the back and I drop him down from about 20m height he kips at the negative pitch at the intercept (without which I roll) to a side away and only at Bank 0 At Bank 1 and 2 it is not Should I stop the head circles? TS is 100% straight Mfg Sascha |
Author: | scrambled [ Sun 16. Apr 2017 11:18:03 ] |
Are you using Google translate? It's not understandable. (I guess you're German?) |
Author: | sascha1603 [ Sun 16. Apr 2017 11:57:16 ] |
Yes i am german and take google translation Greeting sascha |
Author: | Coco66 [ Sun 16. Apr 2017 14:18:25 ] |
Then write in German and somebody will help with translation... |
Author: | sascha1603 [ Sun 16. Apr 2017 16:35:04 ] |
folgendes Problem wenn der Chronos auf dem Rücken ist, und ich von 20m höhe runter hole (auch bei nur 5m) und ich dann negative Pitch gebe zum abfangen kippt er auf eine Seite weg! auch wenn ich negative Pitche und ihn dann wieder mit Positive sacken lasse das gleiche beim abfangen wenn ich ihn z.b. auf dem Rücken schweben lasse, kann ich bei Bank 1 und 2 die Finger vom Knüppel nehmen, bei Bank 0 nicht weil er nicht stehen bleibt sondern auf die Seite weg kippt In der Funke ist alles gleich bis auf den Kreisel und Drehzahlen eingestellt, weder Expo noch Dualrate mfg Sascha |
Author: | scrambled [ Mon 17. Apr 2017 13:45:32 ] |
That roughly translates to: You fly the heli inverted and let it drop. To catch the heli you give negative and at that point the heli rolls on it side. In Bank1 and 2 you can hover inverted, even without your finger on the cyclic stick. However not in Bank 0, then it starts to roll. --- Have you checked the five points ZeXx86 gave you? Is your swash level, also on the point where it sits when inverted? Check with a swashplate leveler tool. |
