Spirit System
Governor- RPM Sensor Testing
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1880
Page 1 of 3
Author:  stipsi [ Fri 10. Mar 2017 17:39:10 ]
Post subject:  Governor- RPM Sensor Testing
Hello
What is the meaning of the red button in sensor testing?
Does it have to be red or green when Gov is active?
Author:  Dn_Spirit [ Mon 13. Mar 2017 11:23:48 ]
Post subject:  Re: Governor- RPM Sensor Testing
this button is normally red, but when RPM sensor is connected and signal is High then it will change color. When RPM signal (voltage level) is low then color is changed to white (Status - Inactive)
Depending on the signal, you might see changes even during motor rotation by hand.
Author:  stipsi [ Mon 13. Mar 2017 20:13:30 ]
Ok, thanks.
Author:  jgiannakas [ Mon 13. Mar 2017 20:15:33 ]
So I tried this on the goblin 500 with HW 100a v3 rpm out and while the RPM reads properly the indicator stays grey! Software bug or do I have a problem?
Author:  ZeXx86 [ Mon 13. Mar 2017 20:30:47 ]
Some sensors are outputting the high/low level as a tiny spikes, so the software may be not able to check fast enough that the signal was high/low.
Probably we will update it little bit so it will be well visible in any case.
Author:  stipsi [ Mon 13. Mar 2017 21:18:33 ]
Oh that would be fine, thanks!
Author:  FrankFuss [ Wed 15. Mar 2017 16:23:02 ]
Is the sampling rate the same on the Spirit and Spirit Pro?
Author:  ZeXx86 [ Wed 15. Mar 2017 18:27:06 ]
Yes, completely same.
Author:  sheva99 [ Wed 29. Mar 2017 14:59:01 ]
When are you going to fix this problem?
Author:  ZeXx86 [ Wed 29. Mar 2017 17:25:39 ]
Hello.
With the upcoming update.
Page 1 of 3 All times are UTC + 1 hour
http://www.phpbb.com/
