[SOLVED] Graupner Hott SumD / Telemetrie https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1850 |
Page 1 of 1 |
Author: | nenno [ Sat 18. Feb 2017 15:22:29 ] |
Post subject: | [SOLVED] Graupner Hott SumD / Telemetrie |
Hi... I have a issue with SumD. When i plug in the accu the Spirit calibrates but the Swashplate pumps 6 times. After that i can't move pitch. Ele, Ail and Rudder are moving. I made i clean Setup with my MZ24. Channels are moving the correct way... but Pitch is shown as channel 6 and throttle is shown as channel 1. This is not the correct channel-order for Graupner... Telemetry integration is working. I use a Unisens-e in parralel. I have only one issue in this combination. I can't enter the Unisens Setup (Unisens is configured as ESC-Sensor). The Setup Menu is not shownm, but the Unisens-E Telemetry-Data is shown. Don't know if it's a problem with the Spirit or the Unisens. Regards - Jens |
Author: | TomasN [ Sat 18. Feb 2017 17:40:35 ] |
Post subject: | Re: Graupner Hott SumD / Telemetrie |
Deleted |
Author: | ZeXx86 [ Sat 18. Feb 2017 18:54:18 ] |
Hi, great! This problem is caused, because you have enabled Rescue mode. So when you will deactivate rescue, it will work. Probably only Gyro Gain is not configured. Here you can see description and solution of your problem: http://manual.spirit-system.com/index.p ... _Solutions Regarding channel mapping, in Spirit there is a different channel numbering, but this is absolutely correct. So you can leave it as is. You only have to change Gyro Gain (increase) and then all will be OK. Probably it is at default value - 0%. |
Author: | buell47 [ Sat 18. Feb 2017 18:55:05 ] |
You have probably rescue activated the whole time. |
Author: | nenno [ Sat 18. Feb 2017 20:13:40 ] |
buell47 wrote: You have probably rescue activated the whole time. You where completly right. My Mixer for Gyro-Channel Reverse was in the wrong way, because the Channel travel and reverses are now in the right way for Graupner... Thanks for the quick help... Regards - Nenno |
Author: | ZeXx86 [ Sun 19. Feb 2017 15:00:25 ] |
No problem. You are welcome! |
