[SOLVED] Spektrum AR8010T / AR9030T https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1804 |
Page 1 of 1 |
Author: | warhog [ Mon 23. Jan 2017 21:44:53 ] |
Post subject: | [SOLVED] Spektrum AR8010T / AR9030T |
Hi, has anyone tried to use SRXL with the new Spektrum AR8010T / AR9030T receivers? Seems like they changed the checksum generation again, at least it is not working with the Microbeast (also with the Spektrum special firmware). From what i read it is also different from the AR7700 SRXL format. Regards |
Author: | ZeXx86 [ Mon 23. Jan 2017 21:59:41 ] |
Post subject: | Re: Spektrum AR8010T / AR9030T |
Hi, I can't answer the question right now. But for sure we will add the support if it will not work. We have implemented more algorithms for this protocol so it is possible it will just work. |
Author: | warhog [ Tue 24. Jan 2017 0:38:52 ] |
Hi, okay, i'll just ordered an AR8010T. Should be in stock during next week. I will keep you updated when it arrived. Thanks |
Author: | ZeXx86 [ Tue 24. Jan 2017 9:30:42 ] |
Hi, great. Thank you very much! |
Author: | warhog [ Tue 31. Jan 2017 20:21:31 ] |
My AR8010T arrived today, everything is working using SRXL awesome Keep up the good work! |
