ZeXx86 wrote:
1) If there is really 8deg then the only explanation is:
- too low flying RPM
- blades are reversed
- measured angle is smaller
2) This can happen, if your Gyro Gain is negative or close to zero - in that case gyro is in the normal mode, while you need to set it for Head Lock mode. In this mode it should not return to center.
You only have to increase gyro gain in your transmitter so in the Diagnostic tab you will see HL, not N or HF.
1) I want zero pitch at the bottom, not in the middle. I started adjusting setting and I clearly have more pitch movement, however the diagnostic tab still says I have -49 pitch at bottom stick, not zero. I can not seem to change this.
2) I have gyro gain set at -65 which was recommended, in order for rescue to work and keep me in self level mode. The diagnostic slider does say HF, but changing this number in the transmitter does not make the slider change to HL.
Jim
