It is currently Sat 23. Nov 2024 22:09:11
PostPosted: Wed 18. Jan 2017 20:57:12
Hi I was wondering if anyone has a dx9 spm file that they could share with me . I have the spirit black installed in my oxy
and was wondering how to set up rescue mode I have absolutely no idea how to go about doing it . could someone post a video on how to set up rescue or bail out modes. The only FBLs I have done are beastx plus and AR7200 THANKS TO ANYONE THAT CAN HELP
PostPosted: Wed 18. Jan 2017 21:10:41
Hi!
I believe that somebody will share their files.
But in the meantime I can point out this guide:
http://manual.spirit-system.com/index.p ... e=Spektrum
The easiest way how to activate the rescue is to set Gyro Gain switch (2-state) in your transmitter.
One where is a positive gyro gain and one with a negative.
If you will be flying with for example 65% gyro gain, then for the rescue set -65%. Negative value will always set the rescue.
In the software you have to just set Stabi/Function to Rescue and then you are done.
Users browsing this forum: No registered users and 28 guests
