It is currently Sat 23. Nov 2024 23:18:54
 Post subject: Spirit and TDR II
PostPosted: Mon 16. Jan 2017 18:49:28
Can you confirm the the Spirit FBL is suitable for the linear servo system in the TDR II? Is there a software setting to disable compensation for non-linear servo movement?
 Post subject: Re: Spirit and TDR II
PostPosted: Mon 16. Jan 2017 19:05:36
Yes, with Spirit FBL you do not have to disable anything.
It is only needed to reduce Geometry 6° by approx. 1/4 (after you will find a precise value).
Then set the Elevator Filter to 4.
Users browsing this forum: Bing [Bot] and 25 guests
