It is currently Sun 24. Nov 2024 0:50:49
 Post subject: [SOLVED] Devo 10
PostPosted: Mon 26. Dec 2016 4:23:11
What is the transmitter set up for a Devo 10 using Deviation firmware? I have a Spectrum satellite receiver, in a Trex 250.
Jim
 Post subject: Re: Devo 10
PostPosted: Mon 26. Dec 2016 13:43:53
Unfortunately I can't say you a details, but there shouldn't be anything special except that the swashplate mixing must be disabled (H1).
This mean that movement of a stick will move just with a single channel.
You will need to bind the satellite in a 22ms mode, else channel reading will be erratic.
This can be done with a bindplug in the SYS port for DSM2 22ms or bind plug in the SYS and next in the ELE/PIT/AIL for DSMX 22ms.
Then only important is to reverse channels so that movements will correspond with movement of the bars in the Diagnostic tab when doing setup.
This is very important.
You can also use Expos 20-30% if you like it.
Nothing else is needed.
PostPosted: Mon 26. Dec 2016 15:40:11
Thank you. I look forward to trying the FBL.
Jim
Users browsing this forum: Bing [Bot] and 67 guests
