[SOLVED] EX-Bus / Jeti / RPM signal? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1753 |
Page 1 of 1 |
Author: | gabs_mex [ Sat 17. Dec 2016 21:20:38 ] |
Post subject: | [SOLVED] EX-Bus / Jeti / RPM signal? |
I just purchase a Jeti, and im planing on using the EX Bus for the integration, my question is this, if i use EX Bus i loose the Governor of the FBL, is this correct? I will have to use the PPM on the reciver to free the input of the RPM signal and only then i can use the Gov, is this correct? or can i use EX Bus and use the middle pin that is free to get the RPM signal and use the GOV? |
Author: | ZeXx86 [ Sat 17. Dec 2016 23:45:31 ] |
Post subject: | Re: EX-Bus / Jeti / RPM signal? |
Quote: if i use EX Bus i loose the Governor of the FBL, is this correct? No, you can use Governor with EX-Bus with no problem. You can use the PIT pin (middle pin) as described in the manual. You can also use UDI protocol with Jeti, but with EX-Bus you will get full integration. |
