It is currently Sun 24. Nov 2024 1:00:11
 Post subject: Power supply
PostPosted: Thu 24. Nov 2016 16:21:31
Hi guys. I've got my first pro which I am going to install on a logo 600. I'm using the ar9020 srxl connection . I have two leads coming from the kontronic esc for power. One goes to the throttle on receiver. Do I put both in receiver or one to the fbl unit. Or both to the fbl unit.I will be using the kontronic governor. Thanks in advance
 Post subject: Re: Power supply
PostPosted: Thu 24. Nov 2016 21:38:33
Hi Clinton!
All the combinations that you have mentioned will work.
But to avoid ground loops, the best way is to connect throttle directly to the unit and second lead of the BEC too.
So AUX1 and AUX2 will be for throttle input and powering.
Receiver can be connected just with a single cable as it require very small current.
Alternatively you can connect BEC and throttle to the receiver and use two cables connected to the unit.
Users browsing this forum: No registered users and 60 guests
