It is currently Sat 23. Nov 2024 23:00:31
Page 1 of 1
[ 1 post ] |
Author |
Message |
IamCxZ
Posted: Sun 16. Oct 2016 7:24:40 |
Ugraded the SpiritPro on my Warp360 and my LaHeli Ricco and wow what an upgrade !
On the Warp I've had some small wag, it just went away. Flies extremely stable, it was very good before - now it's even better.
Ran into the problem with the Governor, ESC wouldn't init with setting 'slow start', changed to fast - now it works again. (using HW 60A V4, Heli linear, P=9, I=0)
Another small niggle was the Jeti integration, I changed limits on the tail, saved settings and pressed OK to leave Device explorer. After that the unit was completely non-responsive, power-cycled the unit and all was good.
On the Ricco I run a non supported mounting (inverted, contacts to the right) Thus it's been a bit twitchy on elevator, since the unit thinks it's aileron. After upgrade this went away, now it flies smooth.
Yesterdays indoorsession was all smiles
Thanks to the developers for a great update.
Top |
Page 1 of 1
[ 1 post ] |
Who is online |
Users browsing this forum: No registered users and 63 guests |
