It is currently Sat 23. Nov 2024 21:33:26
PostPosted: Wed 14. Sep 2016 14:13:10
How can i make the spirit do a blur piro? just cranck up the rudder rot speed to 20?
PostPosted: Wed 14. Sep 2016 19:02:07
Hi!
Yes, you can do so.
Spirit can control rotation in range of +/-2000°/s in each axis.
PostPosted: Wed 14. Sep 2016 19:27:51
The question should be, can your heli do them :)
PostPosted: Sat 17. Sep 2016 14:31:15
Ok, i tried rud rot speed at 20.
(450L heli 95% throttle)
i got this:
https://www.youtube.com/watch?v=4SIF3EU27sY
But i'd like to have this:
https://www.youtube.com/watch?v=Urc9XMuNB1g
Can I make it do this somehow? maybe with endpoint adjustment of the radio, to have like 150% in spirit software?
Spartan does this by at the full stick it turns off HH gyro. (i was told...)
Thanks! :)
PostPosted: Sat 17. Sep 2016 14:44:31
Is the 2nd video of a 450?
PostPosted: Sat 17. Sep 2016 15:05:01
OK, i see your point. But:
I adjustel endpoints in the TX from 100 to 150%, now at full stick spirit diagnostics tab is way over 100% and it made the piros a LOT faster.
Now i will shoot a new video of it. I think it is capable of more, just need a rud rot rate in spirit like 25 :)
PostPosted: Sat 17. Sep 2016 16:06:51
OK, here is the second vid, good part is from 1:30, it should start from there when you click it.
https://youtu.be/mxB_50GyT2U?t=91
Still got the bounce back from right rudder, can't tune it out, and on full right rudder i got a big head wobble. Even with cyclic gain at 30% ( maybe the torque tub is vibrating under the load? )
PostPosted: Sun 18. Sep 2016 12:08:03
Do you want to fly like this all the time or it is only for some testing purposes?
If so, then stopping behavior should be tuned little bit differently, because good, non delayed stops from so fast rotation is almost impossible for any servo/mechanics.
You will need just to play with tail limit to make the stop equal for both directions.
Slower the rotation speed, the easier tuning.
You can try to set gyro gain to a very low value (1%) + high rudder dynamic. This will allow the max possible rate.
Users browsing this forum: No registered users and 37 guests
