Wizard -TDR II? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1624 |
Page 1 of 1 |
Author: | Franky13 [ Sat 03. Sep 2016 8:12:15 ] |
Post subject: | Wizard -TDR II? |
Hello! Under Setup Wizard , there is the TDR Heli . making it the TDR II meant ? I need a setup for the TDR II ! Thank you! Greetings Frank |
Author: | ZeXx86 [ Sun 04. Sep 2016 10:05:41 ] |
Post subject: | Re: Wizard -TDR II? |
Hello, you can use Default preset. Then you can set Rudder Common Gain to 1,3x Pirouette Consistency to 185 Rudder Delay to 0-5 Elevator Filter to 4 For TDR 2 I recommend to decrease Geometry 6° by 10-20 points due to a different Head geometry. This will improve behavior a lot and reduce possible bouncing. |
