It is currently Sun 24. Nov 2024 6:30:43
PostPosted: Wed 10. Aug 2016 8:54:09
Sorry, I've been away from my Spirit Pro for a few months and I just upgraded to 2.02 from the last version of 1.x. Where is the option to change the correction direction of swashplate when the heli is being tilted? I have my stick inputs working fine. Thank you.
PostPosted: Wed 10. Aug 2016 9:11:07
please check the changelog for 2.0 version.
viewtopic.php?f=19&t=1196
You can also find what you have to reconfigure when updating from 1.X.
PostPosted: Wed 10. Aug 2016 9:29:06
I read through that earlier, but it looks like I missed returning to default transmitter settings. Does this mean all channel reverses should be turned off on my DX 6 and then reconfigure?
PostPosted: Wed 10. Aug 2016 10:19:14
Btw, the only combination that works for the stick inputs is elevator reversed on my DX6 and Channel 1 reversed on the Spirit. But then the elevator compensates in the opposite direction.
Also noticed that my swash setting in my transmitter was set to normal instead of 120 degrees. Normal was working fine on 1.x. Should I change it?
PostPosted: Wed 10. Aug 2016 10:36:05
All stick input directions should match with the Diagnostic tab from 2.0.
So you have to use reverses in TX to correct it first.
CCPM 120 in TX is wrong, so you should leave it as is.
I have copied important information from the linked page:
Quote:
After the update it is necessary to re-adjust the following:
  • Channel reverses and Travel ranges in the transmitter (default settings are recommended)
  • Position
  • Swashplate (Check the servo connection)
  • Servo Reverse
  • Subtrim (tuning)
  • Throttle Range (including ESC re-calibration) and possibly Governor. (if used)
All these things are necessary to change, as there are differences.
Users browsing this forum: No registered users and 19 guests
