It is currently Mon 25. Nov 2024 0:33:51
PostPosted: Tue 02. Aug 2016 16:26:04
just getting started after my Spirit Pro arrived . Now I connected Jeti with the Jeti Cable on the EXT Port where normally my Sensor is connected. How can I add the sensor now? Do I only need a Expander E2 or E4 and then just connect Spirit AND Sensor to it?
PostPosted: Tue 02. Aug 2016 20:23:27
unfortunately with Rsat2 it is not possible to connect more than 1 EX Bus device. So it can be used just by this or this.
As far as Jeti explained, it is not possible with Expander. Expander can not work at such high speed as necessary for communication with unit.
It is suitable only for sensors.
On the other hand, you can switch Rsat2 to UDI output - in this case you can fly with it and use telemetry sensors.
But Jeti integration is not possible in this case.
But you can at least first set your unit with Integration and then switch to UDI (when everything is ready).
PostPosted: Tue 02. Aug 2016 21:04:32
Thanks! So learned something new. I will change Receivers. Will remove the Rex out of my HD500 and put it in the Diabolo 550 with Spirit
Users browsing this forum: Bing [Bot] and 90 guests
