It is currently Sat 23. Nov 2024 21:38:28
PostPosted: Fri 12. Aug 2016 9:19:58
RX is a REX3, Spirit pro is connected via EX BUS.
I want to set fail save:
throttle -100%
gyro-sens -30%.
that´s set in the spirit settings, right?
what settings do i need in the TX for fail-save? hold? off?
thanks, flo
BTW: jeti integration is so cool!! :D
PostPosted: Fri 12. Aug 2016 12:46:14
first from all, you have to disable Failsafe in your receiver (through Device Explorer/REX3).
Then you can set failsafe in the unit via Software. Go to the General/Channels window.
There by pressing the Failsafe button you can set failsafe instantly.
It will pickup current positions of the channels and save it as failsafe.
So to you only have to set everything to the state you wish for failsafe and press the button.
Then it is done.
PostPosted: Fri 12. Aug 2016 13:01:34
ok, thanks :P
PostPosted: Fri 12. Aug 2016 13:55:45
works!
Users browsing this forum: Bing [Bot] and 29 guests
