It is currently Sat 23. Nov 2024 20:04:59
 Post subject: Unit position
PostPosted: Tue 05. Jul 2016 9:46:56
In the unit position display where is the front of the helicopter?
 Post subject: Re: Unit position
PostPosted: Tue 05. Jul 2016 11:12:41
The arrow is the front
 Post subject: Setting up Govenor
PostPosted: Mon 18. Jul 2016 0:52:30
I'am trying to set up Governor in Spirit Pro. It asks for throttle Frequency and throttle range.I have a Jeti mezon 160 w/ rpm How do I find these units to use?-I cant find them on the Jeti website.Thanks for your reply-Chris Blom
PostPosted: Mon 18. Jul 2016 20:42:41
For your ESC 120Hz should work good. Default throttle range in the unit is OK.
Unfortunately it looks like this ESC has some delay, so it is question how useable it is for external governor.
In the worst case manufacturer should tell you the values and also best settings for external governor.
Users browsing this forum: No registered users and 54 guests
