It is currently Sat 23. Nov 2024 19:54:17
Christian Blom
Posted: Wed 15. Jun 2016 6:24:26 |
So I was trying To up date unit to 2.0 both in the software and firmware.I made some mistakes along the way.So by reading posts in the forum I managed to get software back to1.3.2 version.Then I flashed spirit-fw-1.3.2man.it downloaded, and then it said to turn unit off first,and then turn it on again and launch software.Well I turned unit off and I tried to power up unit and the led did no light up.I also realized I flashed the wrong firmware which should of been:spirit-fw-1.3.2.4df.What can I do to get my unit to work again?Thanks-Chris
Posted: Wed 15. Jun 2016 7:04:39 |
Christian Blom
Posted: Thu 16. Jun 2016 4:27:35 |
I got it to the recovery mode but when I turned on power nothing happened.
Posted: Thu 16. Jun 2016 7:35:20 |
Please try it again, or with a different computer if you can. And also make sure that installed driver is really correct, which is usually reason why normal flashing can fail.
The USB cable must be connected to the SYS port usually.
Christian Blom
Posted: Fri 17. Jun 2016 3:06:38 |
Thanks for responding.So far I uninstalled all firmware and software relating to the Spirit Fbl unit.How do I recognize the old driver in my computer for the Spirit Fbl unit so that I can get rid of it and install the updated driver as I don't have another computer to work with?Thanks-Chris Blom
Coco66
Posted: Fri 17. Jun 2016 5:59:11 |
Didn't try, but most probably you can connect the Spirit USB adapter to the computer, go in Control Panel, Device Manager, and find it there. There should be options to uninstall the driver.
Christian Blom
Posted: Fri 17. Jun 2016 6:41:47 |
So located the device in computer and unistalled driver .Do I install now the 2.0 software or the 1.3.2 software plus corresponding firmware.Thanks-Chris Blom
Coco66
Posted: Fri 17. Jun 2016 7:44:44 |
Use 2.0.1 directly.
Christian Blom
Posted: Sun 19. Jun 2016 5:56:31 |
I still cant get it to run.I got it in recovery mode,I turn on power,and nothing happens.Driver is current.I have been using Google Chrome as browser so all the program and and firmware is downloading correctly.Old driver has been deleted before I download the 2.0.What is the next thing I can do to fix this problem?Thanks-Chris Blom
Posted: Sun 19. Jun 2016 10:25:52 |
I will send you a special guide that will solve the problem. It looks like the original firmware was rewritten including bootloader. But still it can be fixed.
Please check ny private message.
Users browsing this forum: No registered users and 56 guests |
