WiFi question https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1502 |
Page 1 of 2 |
Author: | torro [ Tue 21. Jun 2016 7:51:35 ] |
Post subject: | WiFi question |
Hi there, Do you have experience with in flight tuning? i´m talking about fine tuning, not sensor orientation or should the wifi module be switched off during flight? I hope the WiFi module communicates with 5Ghz?!? Greets, Flo |
Author: | ZeXx86 [ Wed 22. Jun 2016 8:43:37 ] |
Post subject: | Re: WiFi question |
Hi Fio, I recommend to not do any in-flight tuning. You can accidently change important parameter so it can lead to crash. Also there can be interference issue - because of this, you can use AutoTurn Off feature. This will turn off the module during the flight completely. So you will be absolutely safe. In case of Spirit, you can guess correct values right before the flight. It is possible based on the used components and model. If you try to find best values, I can try to help you with this. |
Author: | torro [ Wed 22. Jun 2016 8:55:16 ] |
hi, ok, thanks. |
Author: | ChrisTTian667 [ Wed 22. Jun 2016 9:29:22 ] |
It may be a cool (security) Feature, when the unit would detect if the helicopter is currently flying (e.g. when esc Signal is > 0%) and then disable such parameters as orientation, servo trimming, .... cheers |
Author: | torro [ Fri 24. Jun 2016 21:15:18 ] |
ZeXx86 wrote: In case of Spirit, you can guess correct values right before the flight. It is possible based on the used components and model. If you try to find best values, I can try to help you with this. It's time Just installed the spirit in the diabolo 700. Savox 2271 at the swash, 2283 at the tail. No gov. Setup wizard is done. So far no Problems or questions. |
Author: | torro [ Sat 25. Jun 2016 10:23:02 ] |
Where can i configure WiFi Auto off? |
Author: | ZeXx86 [ Sat 25. Jun 2016 11:47:10 ] |
Hello, I recommend to set Pirouette Consistency to 185 and Rudder Delay to 0. Cyclic Gain can be around 60%. Rudder Frequency 333Hz for tail. Regarding Wifi module, you can set it at the first page when you connect to the web interface (http://192.168.4.1) |
Author: | torro [ Sat 25. Jun 2016 12:32:54 ] |
Ok, i'll try. I used the WiFi only with the Android app, I didn't find it there. I'm gonna connect with a Browser. Can i use the Browser of the Phone? Greets, Flo |
Author: | ZeXx86 [ Sat 25. Jun 2016 13:21:44 ] |
Yes, you can also use Spirit Settings directly in the web browser without any limitation. |
Author: | torro [ Sun 26. Jun 2016 11:09:47 ] |
Maiden succesfull Flies very well. Good Job |
