Hi Tomas,
maybe you can remind? This problem a have told you in Januar 2016.
Until now I had thougt, I´m just a stupid Jeti noob, but maybe we are 2 noobs, or it is really a Problem?
Here again what i had wrote:1. Bug
Video 1 and 2 show following:
Vid1 starts with bank0 (Stabilisation) > just change a value in this bank0 > safe > choose "Bank Switching via TX" > exit
Vid2 starts with bank1 (Rescue normal)) > just change a value in this bank1 > safe > choose "Bank Switching via TX" > exit.
All is working correct after leaving the setup.
Vid3 starts with bank0 (Stabilisation) > change a value in bank0 > safe > switch to bank1 (Rescue activated) > change a value in bank1 > safe > choose "Bank Switching via TX" (Rescue deactivated) > exit
After leaving the setup the Bank switching and Rescue doesn´t work.
Vid4 starts with bank1 (Rescue normal) > change a value in bank1 > safe > switch to bank0 > change a value in bank0 > safe > choose "Bank Switching via TX" > exit
After leaving the setup Bank switching is working, but If I choose bank0 (Stabilisation) the Rescue function will activated. Absolutly wrong.
Bank 1 and bank2 is working with the Rescu function via momentary push buttom.
Her are the Vids:
https://www.dropbox.com/sh/evmm9fc49i3n ... 80Mla?dl=0
