It is currently Sat 23. Nov 2024 20:01:14
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Thu 28. Apr 2016 12:10:43
Hi Folks,
maybe i'm wrong, but i can reproduce following effect:
Jeti DS16, Spirit Pro 2.01. Works fine basicly.
Bankswitch Channel 7 works after PowerOn.
But, do i get into the spirit settings via TX, change anything and then leave the settings (with save and bankswitch via tx), no more Bankswitch via TX is possible. After Powercycle the spirit, it works again and my changes are active.
What do i do wrong? Or is there a special hint i do nit know...
best regards,
Lars
PostPosted: Thu 28. Apr 2016 12:42:32
Hi Tomas,
maybe you can remind? This problem a have told you in Januar 2016.
Until now I had thougt, I´m just a stupid Jeti noob, but maybe we are 2 noobs, or it is really a Problem? :lol:
Here again what i had wrote:
1. Bug
Video 1 and 2 show following:
Vid1 starts with bank0 (Stabilisation) > just change a value in this bank0 > safe > choose "Bank Switching via TX" > exit
Vid2 starts with bank1 (Rescue normal)) > just change a value in this bank1 > safe > choose "Bank Switching via TX" > exit.
All is working correct after leaving the setup.
Vid3 starts with bank0 (Stabilisation) > change a value in bank0 > safe > switch to bank1 (Rescue activated) > change a value in bank1 > safe > choose "Bank Switching via TX" (Rescue deactivated) > exit
After leaving the setup the Bank switching and Rescue doesn´t work.
Vid4 starts with bank1 (Rescue normal) > change a value in bank1 > safe > switch to bank0 > change a value in bank0 > safe > choose "Bank Switching via TX" > exit
After leaving the setup Bank switching is working, but If I choose bank0 (Stabilisation) the Rescue function will activated. Absolutly wrong.
Bank 1 and bank2 is working with the Rescu function via momentary push buttom.
Her are the Vids: https://www.dropbox.com/sh/evmm9fc49i3n ... 80Mla?dl=0
Goblin 700C Red Carbon, Cool Kosmik 200, Pyro 800-48, MKS X8 HBL 850/880 HV, Spirit-Pro, Jlog2.6GW, GPS-Logger 2
Jeti DS-16 Red Carbon+REX7
PostPosted: Thu 28. Apr 2016 12:53:27
Update:
We diskussing the Problem since 1 hour on rc-heli.de and until now 2 other Pilots have the same problem.
Possible noob counter = 4 :lol:
Tomas....maybe you have to work :-P
best regrads,
Frank
PostPosted: Thu 28. Apr 2016 13:27:02
I think, I've same with FW 1.3.2, because when adjusting the values during the first flights I sometimes observed, that rescue (with pitch) doesn't move the swashplate when testing after flight.
regards Wolfgang
My Helis: Walkera 4G6 2S µBrain, Align T-Rex 250 FBL Microbeast, Oxy 3 Spirit Pro controlled by Jeti DS16
PostPosted: Thu 28. Apr 2016 20:08:18
If I understand the problem correctly, then there is nothing wrong.
The behavior is such, because after clicking Bank Switching via TX you have to switch a bank by the transmitter else it will be still in the bank that was selected the last time through the integration.
So until you use the switch, it will not change the bank.
PostPosted: Thu 28. Apr 2016 20:52:36
We tried this. Does not work. Even without hitting switching tx.
Lars
PostPosted: Thu 28. Apr 2016 21:36:57
Correct. I have also tried everything, but it's not working.
PostPosted: Fri 29. Apr 2016 7:28:06
Let's try a simple example. So you may give us a hint what we are doing wrong.
Copy the same setting to all banks.
Go to bank 0
Enter settings via tx and reduce pitch limit visible.
Save settings
Leave settings
Apply full pitch witch your stick
Change banks by tx - nothing happens!
Power cycle spirit
Change banks, you can see the reduced pitch limit on bank 0 at once.
What are we doing wrong?
Bye the way, yesterday had maiden with vibe 6 and pro. Perfect feeling! I like it!
Best regards,
Lars
Lars
PostPosted: Sat 30. Apr 2016 18:36:08
Hi Thomas,
Could you check meanwhile? Do we have a Bug or a Feature? ;-)
Lars
Lars
PostPosted: Sat 30. Apr 2016 18:56:28
we are investigating the issue, because we can't still replicate it nor find any problem. We have already tested it many times previously and it always working correctly.
Next week we will know more.
Users browsing this forum: Bing [Bot] and 49 guests
