Spirit System
New spektrum full range sat?
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1434
Author:  Alyon187 [ Thu 19. May 2016 3:10:44 ]
Post subject:  New spektrum full range sat?
Are the new quad racer sats able to work with spirit and if so are they better than using the original sat rx?
Author:  Adrian [ Thu 19. May 2016 19:41:30 ]
Post subject:  Re: New spektrum full range sat?
Correct me if I'm wrong, but following what I heard it should work as any other DSMX Sat with Spirit.
Advantage of longer antennas to get out of carbon frames and canopy. As well as real diversity implemented.
Also auto bind, which means it's going into bind if no tx seen after 10 Sec.
So no bind procedure required by Spirit, just wait 10 Sec after powerup and than power up tx with pressed bind button.
Found sucessfull bind info with microbeast (German), so it should work with Spirit as well I guess.
http://www.flugzone.ch/archive/index.php?t-14974.html
http://www.phpbb.com/
