Spirit System
Spirit Pro - Futaba BLS 251? Rescue on DX7?
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1402
Author:  nenno [ Mon 02. May 2016 9:34:06 ]
Post subject:  Spirit Pro - Futaba BLS 251? Rescue on DX7?
Hello...
... i use a Spirit Pro in my logo 480 XXtreme for some months. Runs absolutely problem-free. After I was now convinced by the Spirit, I also equipped my Voodoo 600 with a Spirit Pro. Yesterday was "First Flight". Absolutely no problems ... I use the default settings taken from Logo 600. Had only to reduce the swash plate sensitivity from 55 to 50 (slight bounce back).
I have a Futaba BLS 251SB on Tail. Servo Delay is on 3 ... Can I possibly go to 0?
A colleague was also very impressed by the Spirit... wants now also one ... Problem is that he has a Spektrum DX7 (the old one). But I have no idea how to setup the DX7 (and he, unfortunately, not really too). I have a Graupner MZ24. How do I program a mixer or somthing like that to get the rescue function to work?
Thanks ... Nenno
Author:  ZeXx86 [ Mon 02. May 2016 9:50:25 ]
Post subject:  Re: Spirit Pro - Futaba BLS 251? Rescue on DX7?
for this servo you have to set Rudder Delay to 0 and Pirouette Consistency increase by 10-20 than normaly. So it might be around 180-200.
The easiest way how to enable rescue is to set two Gyro Gains.
One for flying, one for the rescue activation. So when you want to engage the rescue, you can just switch the gain.
With small hardware modification you can have a momentary switch for this - this is the best solution for the rescue.
To solve bounce-back issue, you can increase Elevator Filter by 1 - 2 values.
http://www.phpbb.com/
