It is currently Sun 24. Nov 2024 11:39:19
[ 6 posts ] |
scvflyer
Posted: Sun 17. Apr 2016 21:17:59 |
Hi Serviceteam , as I read that fail safe could be set in spirit system when RX (GR24) is connected via SUMD to spirit. I did as recommended but it didn't function. In detail - motor stop and setting pitch to -2°. Important - I used spirit app at Android. I simulated fail safe by switching off TX (MZ18). Did I anything wrong ? br Siggi
Posted: Mon 18. Apr 2016 7:28:52 |
maybe the failsafe mode was not really activated. Can you verify if there is Receiver signal lost event in the log when you turn off your transmitter, please? If no, then there is a problem.
scvflyer
Posted: Mon 18. Apr 2016 20:31:55 |
Hi, I found two messages frame receveid corrupted and after that good health message while tx still off ! by he way - i checked it at the channel view - is it okay ? br Siggi
Posted: Tue 19. Apr 2016 7:17:30 |
This mean, that the receiver is sending data all the time without noticing of frame loss. So the unit can't check, that signal was lost. In this case you have to either disable Failsafe in your receiver or to program it directly in your receiver/transmitter.
scvflyer
Posted: Tue 19. Apr 2016 15:12:41 |
Hi serviceteam, okay I will use RX Failsafe options. How can i disable spirit's fail safe options I already saved. br Siggi
Coco66
Posted: Tue 19. Apr 2016 16:02:49 |
As far as I understand, you don't have to change anything in Spirit.
What is currently happening is that the Receiver does not have its own failsafe set, AND apparently it does not tell the Spirit that he does not have connection and that Spirit needs to go in failsafe.
Once you will configure failsafe in your Receiver, it will start "telling" the Spirit that it does not have connection, so the Spirit will execute its failsafe.
[ 6 posts ] |
Users browsing this forum: No registered users and 41 guests |
