Spirit and Jeti Centralbox 200 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1361 |
Page 1 of 1 |
Author: | sacha [ Fri 15. Apr 2016 15:04:50 ] |
Post subject: | Spirit and Jeti Centralbox 200 |
Hello I'm a big fan of the Spirit System and i have converted already several birds. Now i run into a problem: The Setup is the following, jeti transmitter: Jeti RSAT2 (EX-BUS)-> Jeti Centralbox200 -> (EX-BUS) -> Spirit Pro (2.01) When i connect the Spirit to EXT1 (EX-BUS) connector on the centralbox i see both devices (Centralbox200 and Spirit) in the transmitters device-explorer. But i'm not able to enter/select the Spirit or the Centralbox. I got the message, that the device is not online. When i connect the Spirit to EXT2 or EXT3 (EX-BUS) connector on the centralbox i can enter/select the Spirit pro, but not the Centralbox. I see both devices, but i'm only able to select and enter to the Spirit. When i unplug the Spirit pro, i can always enter and configure the Centralbox. Thanks Sacha |
Author: | sacha [ Fri 22. Apr 2016 7:00:25 ] |
Post subject: | Re: Spirit and Jeti Centralbox 200 |
Dear Spirit Team. Any suggestions / opinions ? Thanks Sacha |
Author: | ZeXx86 [ Fri 22. Apr 2016 7:09:18 ] |
Hello, unfortunately we can't respond to this question appropriately. You should ask Jeti support to clarify this. In any case I will try to get this information from Jeti too. I believe that centralbox is missing required data for Spirit (it needs e.g. Spirit BIN file). |
Author: | 7kyf0x [ Fri 22. Apr 2016 8:46:05 ] |
Post subject: | 7kyf0x |
May I ask you a question Sacha? I am a little curious. Where do you use this combination of CB200 and Spirit? On a Plane? Sorry for being OT, but I am really looking forward to have a Spirit in my Krill Extra 330SC. Thanks Ingbert |
Author: | sacha [ Fri 22. Apr 2016 13:14:32 ] |
@ZeXx86 Thanks for your answer. I don't think that the CentralBox200 needs a .bin file. The CB200 together with 2 RSATs is basicaly a redandent receiver with 3 ext-bus outputs. Sacha |
Author: | sacha [ Fri 22. Apr 2016 13:16:12 ] |
@7kyf0x I will use it on a Heli. A Velos880. Sacha |
Author: | phoinix [ Wed 16. Nov 2016 20:52:42 ] |
I'm having problems with Spirit PRO and CB200 connected via EX bus. CB keeps falling offline and of course to failsafe. I have two seperate systems with same result, hardware error excluded. Do you have the same problem? |
Author: | ZeXx86 [ Wed 16. Nov 2016 22:00:09 ] |
We are investigating the issue with Jeti. It looks like there is some issue with CB200 so that it can't handle EX Bus connection well. |
