It is currently Mon 25. Nov 2024 15:32:59
[ 3 posts ] |
felixthemaster1
Posted: Thu 14. Apr 2016 1:11:07 |
My spirit doesn't seem to do it correctly. I tried to use it with and without the orange RPM sensor. Normal mode (around 65%) was perfect but when I got to UI1 with the sensor, it went to a random headspeed that I did not set. And In UI2, went to max head speed (at 90% throttle), So i tried without using the RPM sensor and normal mode was fine until it blended into some random headspeed that didn't change when i went to UI1 or UI2.
What I did in the software was, click on enable gov, input the heli info, put in 3300 as max headspeed, changed holding performance at 1 (since headspeed was pulsing) and then saw the values in software as i spooled up the heli. I noted these numbers down to comapre to the tachometer readings in real life.
I'd love it if I set it up wrong as I really want to use the gov on the spirit especially with the RPM sensor.
Coco66
Posted: Thu 14. Apr 2016 8:23:42 |
First of all, you cannot use the gov without an RPM sensor... think about it: how would the unit know that it has to react to keep the headspeed constant, if it has no way of knowing the headspeed?
Dawiev
Posted: Thu 14. Apr 2016 10:03:25 |
Hi, the RPM Meter section in the Gov / Throttle menu will show you whether you're getting signal from the sensor.
Spool up without blades, conneced to app or software. With a flat throttle curve you will see "Requested RPM" and "Current RPM". If Requested RPM is not stable (with the flat curve, then there's something strange in TX / RX settings . If the Current RPM is 0, you know the sensor is not working.
I believe you can also look in the log for RPM sensor noise warnings and you can increase the noise filter to make it more tolerable in needed.
[ 3 posts ] |
Users browsing this forum: Bing [Bot] and 18 guests |
