It is currently Mon 25. Nov 2024 11:51:06
 Post subject: Spirit pro.
PostPosted: Mon 11. Apr 2016 10:58:28
Every time i connect my spirit pro to my laptop it says this is the first time it has been detected and asks if i want to go throught the setup wizard. I have done the wizzard twice now and it still asks this when i connect it.
I dont have this problem with my other spirit pro on my 550. Both are on the latest firmware.
 Post subject: Re: Spirit pro.
PostPosted: Mon 11. Apr 2016 10:59:49
Did updated to the latest software (2.0.1) as well?
The problem that you described is solved there.
PostPosted: Mon 11. Apr 2016 16:25:29
nzflyer, this may be the same problem I had. Check the following thread.
http://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1289&p=14288#p14288
PostPosted: Mon 11. Apr 2016 20:03:23
tanks for the link Frank. I got the same issue, after upgrading to 2.0.1.
Deleting spirit-wizard.cfg file from my Documents directory solved the problem.
Users browsing this forum: Google [Bot] and 5 guests
