Spirit System
Stick priority
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1335
Author:  henrikbach [ Sun 03. Apr 2016 8:53:15 ]
Post subject:  Stick priority
Is Stick priority doing the same with the flying feeling as expo in the RX ?
Kind regards Henrik
Author:  ZeXx86 [ Sun 03. Apr 2016 10:23:47 ]
Post subject:  Re: Stick priority
No, it is very different and should not be used instead of Expo.
Spirit unit does not use any expos internally, so you can set e.g. 25% in your TX.
Stick Deadband is just to match precision of your transmitter. Value of 10 should work fine with the most transmitters.
Author:  henrikbach [ Sun 03. Apr 2016 11:23:44 ]
Yes, I know what stick deadband does. But what exactly does STICK PRIORTY do ? The function is in the stability tab.
Author:  bill rob [ Sun 03. Apr 2016 14:27:05 ]
so is stick priority just deadband?
Author:  ZeXx86 [ Sun 03. Apr 2016 14:43:21 ]
Sorry, my fault.
Stick Priority determine a degree to which you can control cyclic while the special mode is enabled.
When it is 0 you can't control it at all with your sticks (aileron/elevator).
So this will allow you to set how much you change direction.
Author:  henrikbach [ Sun 03. Apr 2016 15:00:20 ]
OK, that make sense. The value is 0 to 16.
Is 16 equal to 100 % stick priority and 8 equal to 50 % and vice versa ?
Author:  ZeXx86 [ Sun 03. Apr 2016 15:09:31 ]
Yes, it is.
Author:  henrikbach [ Sun 03. Apr 2016 15:30:28 ]
OK. Thank you :D
Author:  bill rob [ Sun 03. Apr 2016 15:50:30 ]
Forums are great,instant fix or understanding :D
http://www.phpbb.com/
