defective device? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1296 |
Page 1 of 1 |
Author: | kraeuchi [ Fri 18. Mar 2016 14:06:55 ] |
Post subject: | defective device? |
Hi, I suspect my spirit pro is faulty. But to be sure, here what it behaves like: Its a new device, new heli. Cabling was done, initial config of the spirit was done, no problem. Today I wanted to continue with the setup and the spirit is flashing for about a minute during bootup until it is ready. I then updated from 2.0 to 2.01 - no change. After boot everything seems ok at first, i.e. there is connection to the software and all parameters can be adjusted, BUT: servos do not move. Not even when I check the subtrim on the servos page. Looks like a faulty device or is it just me? thanks, rolf |
Author: | ZeXx86 [ Fri 18. Mar 2016 14:43:21 ] |
Post subject: | Re: defective device? |
Hi, can you describe your wiring when the issue occured for the first time? How did you powered the unit? We will sort it out together. |
Author: | kraeuchi [ Fri 18. Mar 2016 15:07:04 ] |
Wiring is as described in the manual for Jeti EX bus. The split cable from receiver (rex7) to "RUD" and "ELE/PIT/TAIL". Power from BEC (6V) to "AUX1". Rudder servo on CH4 and swash servos on CH1-3. Interface on SYS. I remember one of the things I did was adjust servo frequencies, i.e. 200Hz for the fubaba bls452 and 560Hz for the tail servo Hitec HSG-8315BH. thanks for your help! |
