Tail Setup https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1283 |
Page 1 of 1 |
Author: | 3DNot [ Tue 15. Mar 2016 17:35:48 ] |
Post subject: | Tail Setup |
Hi, Please can you clarify the correct tail pitch when the rudder servo is centred? The manual indicates the tail pitch should be zero, however, all other FBL units I have used require 2-3 degrees against the torque. If this is zero, will the heli rotate when the gyro is in rate mode? Thanks |
Author: | jgiannakas [ Tue 15. Mar 2016 17:36:32 ] |
Post subject: | Re: Tail Setup |
Check here: viewtopic.php?t=1279 |
