[SOLVED] Bluetooth +app not saving changes https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1271 |
Page 1 of 4 |
Author: | velocity90 [ Sun 13. Mar 2016 15:41:28 ] |
Post subject: | [SOLVED] Bluetooth +app not saving changes |
Im i suppose to save the changes I make manually? If I disconnect it says changes are not saved. |
Author: | ZeXx86 [ Sun 13. Mar 2016 16:29:45 ] |
Post subject: | Re: Bluetooth +app not saving changes |
It works in the same way as the PC software. You should save settings to the unit if you want to store it permanently (not loose with a battery disconnection). |
Author: | velocity90 [ Sun 13. Mar 2016 17:02:43 ] |
Ok where can I find the save function? |
Author: | ZeXx86 [ Sun 13. Mar 2016 17:08:14 ] |
In the context menu - there are many other functions as well. Just press the Menu button or "3 lines" icon. |
Author: | velocity90 [ Sun 13. Mar 2016 17:59:13 ] |
That explains, menu button not working on my nexus 9 tablet . (Android marshmallow) It does on my phone(kitkat) |
Author: | error414 [ Sun 13. Mar 2016 22:31:40 ] |
you can tap to "three blue dots" on top-right on screen or you can slide from left to right and then tap to "menu" check this |
Author: | velocity90 [ Sun 13. Mar 2016 23:15:09 ] |
I know, doesn't work on my nexus 9 (marshmallow) does on kitkat |
Author: | Coco66 [ Mon 14. Mar 2016 0:01:28 ] |
velocity90 wrote: I know, doesn't work on my nexus 9 (marshmallow) does on kitkat Also sliding does not work? |
Author: | velocity90 [ Mon 14. Mar 2016 5:44:27 ] |
Sliding does work but the menu button does nothing |
Author: | error414 [ Mon 14. Mar 2016 10:10:08 ] |
hmm this is problem Do you use android from google or some custom ROM? It seem that I have to rewrite menu in android app. |
Page 1 of 4 | All times are UTC + 1 hour |
