Spirit System
resque
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=1259
Author:  john1127 [ Tue 08. Mar 2016 22:47:31 ]
Post subject:  resque
I'm comfused. I have bank 0 stab nor bank1 stab acro and bank3 resque.
At neg pitch res give pos pitch, at flying pitch at 6. resque on ground levels swash but cuts pitch down to about 4.
Is this normal have pitch slider set to 80. Thks, have flown with spirit for months but never had banks turned on yet.DX8 with sat. thks
Author:  ZeXx86 [ Tue 08. Mar 2016 22:56:04 ]
Post subject:  Re: resque
rescue is working independently of your stick input. So anytime you will activate it, it should give you a positive pitch.
When rescue or a special mode is activated, you will see "HF" in the Diagnostic tab, not "HL".
Remember, when you are testing banks, you have to close the software. If software is running, active bank is selected there.
What version do you use? 2.0?
Author:  john1127 [ Tue 08. Mar 2016 23:10:58 ]
Yes I'm using 2.0 Iam unplugged and at low throttle neg pitch and hit resq swash levels and gives pos pitch. at 3/4 throttle about =7 pitch, hit resq swash levels and gives only about +4 pitch, I have resq slider at 80 percent. thks.
Do I have to set pitch for each bank or are they all Okay?
Author:  Alyon187 [ Wed 09. Mar 2016 2:05:44 ]
You need to transfer your collective pitch slider number to all three banks.
Author:  Coco66 [ Wed 09. Mar 2016 8:04:35 ]
The software's Bank comparison feature is your friend...
Author:  velocity90 [ Wed 09. Mar 2016 22:38:02 ]
Where can I find this?
Verstuurd vanaf mijn HIGHWAY SIGNS met Tapatalk
Author:  Coco66 [ Thu 10. Mar 2016 7:52:26 ]
In the software it's on the Backup tab (the button is only viaible when Banks are enabled).
In the App is Menu / Banks / Comparison (never actually tried it there).
Author:  john1127 [ Thu 10. Mar 2016 10:01:00 ]
Ive got all 3 modes pitch set the same. Have resque pitch slider set to 70. It is about 7 degrees, So if I hit resque whe flying at 9 degrees, the heli will actully drop and level, is this normal?
Author:  W.W. [ Thu 10. Mar 2016 11:41:23 ]
If you need 9° for flying then 7° on rescue would be to low, but I think 7° should be more than necessary to hover, but when trying 3D it could need more than that to save the helicopter, because you have to compensate a downward motion.
This parameter you have find out in flight.
http://www.phpbb.com/
