It is currently Sun 24. Nov 2024 18:07:51
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
PostPosted: Mon 28. Dec 2015 5:27:57
Season's greetings to all !!
Hi, I'm using a Spektrum DX9 and want to use the AUX 2 channel for a switch. Is it possible to do this without a receiver ?
Software only allows the assignment of 7 channels ?
PostPosted: Mon 28. Dec 2015 11:40:02
you are right. Spirit units can use 7 channels - there is no need for more.
It is possible that with some update it will be supported with Spirit Pro.
But you can always use recommended way by Spektrum - classic receiver.
For example latest receivers (AR7700) are supporting serial output and AUX2 output at the same time.
PostPosted: Mon 28. Dec 2015 11:59:55
Hi, thanks for the reply.
Yes, there is a need for more than 7, else I would be asking ........... ;) As it stands, the Spirit uses all of the channels for it's own requirements and leaves nothing for external use.
Can I change the bank channel to drive this external switch ? (At least until such a time as the software catches up with the hardware abilities ? :D )
I already have the FBL and the telemetry unit mounted and now have to find place for a receiver too ? For one switch (remote glow driver for the nitro on one and external governor on another).
If the Pro has the plugs and ports for all the different connections, surely it should be easy to adjust the software for channels 8 & 9 ? Or, make CH 0 available for Spektrum please.
PostPosted: Mon 28. Dec 2015 14:58:07
I too would like to see the possibility to use all the ports on the Pro as I want. I'd like to use channel 8 and 9 from the AR7700 (via SRXL) to control tail gain and banks on the Pro, so I can use channel 5 and 7 on the AR7700 to control other things. I hope this will be added on a later firmware. :)
PostPosted: Tue 29. Dec 2015 5:21:45
Hi, when can we expect FW 1.4 please ?
I see that you responded to Coco66 in September that we might see the use of free channels with this release.
PostPosted: Wed 30. Dec 2015 8:14:14
I am sure that in the future there will be this feature available. Hopefully in 1-2 updates. Unfortunately I can't tell you exact date.
PostPosted: Wed 30. Dec 2015 9:14:16
Thanks !!
PostPosted: Wed 30. Dec 2015 10:04:09
So I will finally be able to convert my NightFlyer to Spirit... yoooohoooo!
PostPosted: Mon 07. Mar 2016 19:13:21
So if I get a AR7700, for my Spirit Pro, I will be able to use the Aux 2 output on the AR7700 for an external channel?
Would this take away my adjustable banks?
Larry
PostPosted: Mon 07. Mar 2016 21:12:46
Yes please ch8!
Verstuurd vanaf mijn HIGHWAY SIGNS met Tapatalk
Users browsing this forum: Flapflap, mainstreet and 82 guests
