It is currently Sat 23. Nov 2024 14:20:29
PostPosted: Sat 19. Mar 2016 19:44:17
I am currently setting up my Oxy3 and want to use the spirit governor.
So following the manual:
"Gear Settings - Gear Ratio
Gear Ratio of the helicopter between the main wheel and pinion of the motor. For example: 120T main gear / 12T pinion = 10."
In my case: 140 main wheel and pinion 10 results in 14. My problem is now that the max value is: 12.7
Any advice how to fix this?
Thanks a lot for any help in advance,
Andreas
PostPosted: Sat 19. Mar 2016 20:00:05
This thread has your answer...
http://spirit-system.com/phpBB3/viewtop ... &view=next
PostPosted: Sat 19. Mar 2016 20:15:33
Coco66 wrote:
Thank you very much for this ultra fast answer. Seems like I need new glasses :) Didn't find this thread.
PostPosted: Sat 19. Mar 2016 22:03:41
I just remembered I read it and made a Google search.
Not sure I myself understood the idea about faking the sensing divider though ))))
Users browsing this forum: No registered users and 40 guests
